trans fluid
Csbbrah
Ky
Is there a drain plug on the trans pan? It is a job for the DIYer?
Thanks, Tom
Yes sir. Very easy to do. You dont even have to lift the car if your arms are long enough. Will be able to drain about 5 qts out. Trans is filled through the dipstick under the air box. Easier than changing the oil.
Sent from my LM-Q610(FGN) using Tapatalk
tomsho
belle vernon PA
Thank You
