MorpheusGPR
Ford TRIO
I will be dropping the pan to do pan filter and fluid change soon.
I know guys said the dealer is not the way to go but I want to make sure its the correct equipment. I am not a fan of FRAM.
How many quarts of fluid will I need?
What filter will I need?
Is there an easy way to put a drain plug in, or pick up a different pan that has one in it already to make it easer and cleaner in the future.
What fluid is the best to use for this particular tranny? I did a new valve body on my lightning and when I did that it took 11 quarts or so but I added a high capacity moroso pan w/ drain plug and also I just used the good ole ford tranny fluid to replace it...it is also synthetic fluid (the ford fluid).
How much of a PITA is it to install a tranny cooler at this time? Where do you mount it and does it run in conjunction with the stocker or does it phase the stocker out?
Thanks.
p.s. if adding a tranny temp gauge in the future does that change anything?
Thanks.
