TPS sensor reset procedure
'94SHO
Towley rules!!
R.I.
Do you mean how to zero it in? Or how to reset the computer?
The TPS has no memory to reset.. It can be adjusted to the proper voltage,
Something like 1.1v at idle? Don't quote me on that.. Usually,if they are out of range, the the adjustment needed (percentage wise), does not matter..
If it is so far out that you need to elongate the holes, you should just get another one.. They can vary (out of the box) by a tenth of a volt or more.
Do a search on TPS, there are some good threads there, with all the correct
specs.:thumb:
