I use this tool for my TPMS sensors:
(Tire Pressure Monitor Activation Tool)
You don't say if you still have access to the original sensors. If so, you can read the ID from them and program the ID to the new sensors. Also be sure that the sensors are programmed to the correct frequency, 315 not 433
This is the procedure from the Ford service manual
SECTION 204-04: Wheels and Tires |
2010 Taurus Workshop Manual
| GENERAL PROCEDURES | Procedure revision date: 07/07/2009 |
Tire Pressure Monitoring System (TPMS) Sensor Training — Intelligent Access (IA)
NOTE: If the vehicle has been stationary for more than 30 minutes, the sensors will go into a "sleep mode" to conserve battery power. It will be necessary to wake them up so they will transmit the latest tire pressure information to the Smart Junction Box (SJB). For additional information, refer to
Tire Pressure Monitoring System (TPMS) Sensor Activation in this section.
NOTE: The tire pressure sensor training procedure must be done on a single vehicle, in an area without radio frequency noise and at least 1 m (3 ft) away from other vehicles equipped with a Tire Pressure Monitoring System (TPMS).
Radio frequency noise is generated by electrical motors and appliance operation, cellular telephones, remote transmitters, power inverters and portable entertainment equipment.
NOTE: If a sensor does not respond to the Tire Pressure Monitor Activation Tool, attempt to activate the same sensor with the Tire Pressure Monitor Activation Tool. If the sensor still does not respond, move the vehicle to rotate the wheels at least one-fourth turn and attempt to activate the same sensor again.
NOTE: The SJB has a 2-minute time limit between sensor responses. If the SJB does not recognize any 1 of the 4 tire pressure sensors during this time limit, the horn will sound twice and the message center (if equipped) will display TIRE NOT TRAINED REPEAT and the entire procedure must be repeated.
NOTE: For vehicles with different front and rear tire pressures (such as the E-Series and certain F-Series), the tire pressure sensors must be trained following a tire rotation. Failure to train the sensors will cause the TPMS indicator to illuminate. For vehicles with the same tire pressure for front and rear tires, tire rotation will not affect the system.
NOTE: Refer to Description and Operation, Intelligent Access (IA) with Push Button Start in
Section 419-01B to review the procedures for achieving the various ignition states (ignition in accessory, ignition on, ignition start, ignition off) on vehicles with this feature.
- With the ignition OFF, press and release the brake pedal.
- Using the start/stop switch, position the ignition from OFF to RUN 3 times, ending in the RUN position.
- Press and release the brake pedal.
- Position the ignition to OFF position.
- The horn will sound once and the TPMS indicator will flash if the training mode has been entered successfully. If equipped, the message center will display TRAIN LF TIRE.
- NOTE: It may take up to 6 seconds to activate a tire pressure sensor. During this time, the Tire Pressure Monitor Activation Tool must remain in place 180 degrees from the valve stem.
Place the Tire Pressure Monitor Activation Tool on the LF tire (banded sensor) sidewall opposite (180 degrees) from the valve stem or (stem mounted sensor) sidewall next to valve stem. Press and release the test button on the Tire Pressure Monitor Activation Tool. The horn will sound briefly to indicate that the tire pressure sensor has been recognized by the SJB .
An animated version of this procedure is available on-line.
- Within 2 minutes of the horn sounding, place the Tire Pressure Monitor Activation Tool on the RF tire (banded sensor) sidewall opposite (180 degrees) from the valve stem or (stem mounted sensor) sidewall next to valve stem and press and release the test button to train the RF tire pressure sensor.
- NOTE: Do not wait more than 2 minutes between training each sensor or the SJB will time out and the entire procedure must be repeated.
Repeat Step 7 for the RR and LR tires.
The procedure is completed after the last tire has been trained. When the training procedure is complete, the message center (if equipped) will display TIRE TRAINING COMPLETE.
For vehicles not equipped with a message center, successful completion of the training procedure will be verified by turning the ignition switch to the OFF position without the horn sounding. If the horn sounds twice when the switch is turned to the OFF position, the training procedure was not successful.
- Using the scan tool, locate the updated TPMS sensor identifiers trained to the SJB and document them on the applicable warranty claim.
- NOTE: This step is required to clear DTC C2780, cause the SJB to exit the manufacturing mode and to make sure there are no other concerns with a newly programmed SJB .
If the sensors are being trained due to the installation of a new SJB , clear any DTCs and carry out the SJB On-Demand Self Test.
