Tore up my tie rod
Devin
3.Slow
Pacific Northwest
I few months back I reversed into a drainage ditch. Afterwards I noticed a clunking noise when turning. I haven't driven it in a while but I went to look at it today and my driver side engine damper bracket was completely off of the tranny mount. I reaffixed that with a single nut (for now) and looked a bit closer and noticed that I had grease coming out of a two inch long crack in my outer tie rod boot.
This really sucks because I purchased it brand new, and there's probably not even 4000 miles on it. Can I replace the boot and regrease it (there is a grease fitting)? That would save me some money as well as an alignment most likely.
Yes, since there was still grease present, the rod end should be okay - with no play. You should be able to replace the boot by removal of the rod end bolt to the knuckle, but the boots are not normally sold separately.
Devin
3.Slow
Pacific Northwest
I called a store and they might have the boot but I need to bring mine in. When I put the boot and end together and torque it down, do you think it'll affect my alignment?
How do I check if there is play?
Devin
3.Slow
Pacific Northwest
I don't know if the ball joint is still in good condition but I'll take it on a test drive today.
I got a 5/8 boot, put a couple fingers of grease on the stud and torqued it down to 42ft/lbs. A little bit of excess grease squeezed out but it looks okay so far. I guess I'll have to take the wheel off after a couple drives and see if it is still retaining the grease.
