ohioshodude
SHO'ld fogy
hello all. well as some of you know my sho has been out of commission for oh about 2 years now. i've tried to start it every two weeks or so but as i'm busy, sometimes i forget about it. it has been about a month and a half since the last time i started it. over the last 4 times i've started it it's developed a knock in the top end. using the "poor mans stethescope" (screw driver) i've narrowed the sound down to the front, passanger, intake side of the valve cover. i also get the noise from the intake area on the rear valve cover but not nearly as loud. as it has nearly 180k miles and probably never had a 60k i'm sure its well over due, and possibly part of the problem. i guess i'm asking if this is serious or if its just normal from being out of spec. if nothing else i may tear it down in a few days. thanks!
a rod knock. : Let's hope it's the belt or a shim. I doubt it's a rod knock, but with that many miles and no 60... If you can, stick your finger in there and check the rod bearings...
