Redskull
Badass Mo'fo
Lately, my power steering has been exhibiting some wild problems, that I can only diagnose as being possessed by demons. The first thing I noticed was alot more noise during assist: like a cross between a hissing and a gurgling. Then I noticed that the further I try and turn the wheel, the more of a fight the system puts up against it. This is where things get funny: If you let up slightly, the system will provide a pretty hard 'kick' putting the wheel back to center. But if you *increase* the turn slightly, the system will provide a nice kick in the direction you want to turn, before it starts fighting you again. To make matters worse, it also seems related to engine speed. If i'm sitting still, with the wheel turned slightly enough to engage the assist, and then goose the engine a few hundred RPMs, the 'fighting back' dissapears and I get a kick in the direction of the turn. But when the RPMs come back down, the 'fight back' increases, and the wheel turns itself back to where I originally had it. The fluid is full, the air has been purged, and I got a new pump about a year ago. I was thinking maybe a malfunctioning check valve? Has anybody else ever had this problem? Can anbody recommend any troubleshooting steps to isolate what the problem might be?
alan
alan
