The BEST sparkplug??
JoesSHO
Reality
Might be different for the V8's, but like Paul and because of Paul's reccomendation :)biggrin:) I use the Iriduims as well.
shobote
Naperville, IL
Using E3 plugs and they work great and fit perect. Formerly used AC Rapidfires and they also worked very well for many years with no problems.
Sho Amo
SmkTyresntDrugs
Olney, Md
i like autolites. the 3924 is the stock heat range and i recently went colder (3923) because of the nitrous im going to use.
honestly, my car runs better with this colder range spark plug without the nitrous. im probably going to end up running them even if i stop using the juice.
blownsho94
Pennsylvania
Thanks to all!! I used the Ford Autolites. The boots fit tight and I received a great price on them. I need reliability vs. keeping up with the Joanses, as some want.
-- Kevin
LJRuddy
Pop lock n drop
Poaceae fields
Autolite XP iridiums. You can almost always get a rebate too.
x2. I've used these on 3 different SHOs multiple times. A little pricey (iridiums always are) but they are worth it and they fit the SHO's plug boots quite nicely and last for ever. :wave:
zblackbeast
SHOtarded
Omaha, NE
I just put in some APP3924s autolights from NGK Lasers and WHAT A DIFF.. i recommend the autolights
