testing the coilpacks...
DavidT
TN
Using a multimeter, how would I test the coilpacks to see if they are good?
99V8SHO
GasOilAndTires
Gaithersburg, Maryland
Wouldn't it just be easier to pull the coil off the plug? If the car idles like doodoo then the coil is good. If you pull one and idle quality does not change then you have found the faulty plug.
DavidT
TN
well, its very spoaradic. It only does it occasionally, and the shifter has to be in DRIVE. It doesn't do it in neutral. If it is a coilpack, I suspect it is a minor problem NOW.
Hard to check them with an ohm meter. When the finally fail and open up the windings then you will get no reading. The problem is the coil will discharge to ground before the time is right as the coil normal normal circumstances is hot all the time. The PCM will ground the coil when the proper spark time is due.
You could try pulling the coil out, connecting it to any of the coil wire plugs. The get a piece of wire, ground one end of it. Using the other end to "sniff" around the col body particularly at any cracks. If the coil is bad it will discharge. Look out for the the 20k volts though.
