sway bars ?
PROPHET
Well-Known Member
Tonytown, Texas.
what size sway bars in a 92,and what would be best for performance ,would 24mm and 26mm be good?
SHO5
ADDICTED
Fond du Lac, WI
i want either a 28 mm or a 26 mm i also have a 92 and want better handling what would the prices be on each of these and which has best overall balance.
SHODWN
Mother Threasa
Spencer,Ma usa
I have a set that are ending today on Ebay, the 24 and 26 set. Most everybody has always used this set for better handeling. I know it made a WORLD of difference on the Gen 3.
I wont/cant post the link here though but they are there on Ebay for a short while longer..
noSHO
ohio is for hustlers
I've always felt 24/26 was only good because at some point someone said it was. It's cheap and easily obtained, but IMO it isn't the best handling combo. It's good for the Automatics as I understand it, but for an MTX SHO it is too much front bar/not enough rear bar. I think 24/28 is probably the most optimal neutral setup. It still understeers when pushed hard, but is neutral otherwise. It's more expensive though, but the more I deal with car stuff in general, the more I find out that you get what you pay for. Take it FWIW.
