sway bar question
Dr_Thompson
CT
hey everyone. last year when i did a clutch job i screwed something up and the rod shifter pulsated up and down when i drove. I had replies on the forum saying that i put the front sway bar in upside down/backwards. Im doing the job now and to be honest im not sure how its supposed to look.i dont even see how you can put it in backwards to be honest, it looks like if i flip it around its gonna be the same.anyone got pics or describe it to me?
NJSHO
Clean Your Shorts!
NJ
I had that happen when I put a 22mm front swaybar in. Put the sway bar in the other way (ie took left side and made it the right) and it solved the problem. I don't have any pictures so your gonna have to trust me.
We can't stop here, this is bat country...
93rev2sev
Hockeytown
Sounds like I have a winner (same problem). Guess I'll be doing a sway bar R/R write up today.
Loosen subframe bolts in front, put jack under rear of subframe, remove rear subframe bolts, lower jack, remove 4 13mm bolts, wiggle sway bar out...switch it around, wiggle it back in, reassemble and get an alignment. It was pretty easy.
