24mm front sway bar upgrade
I think that the upgrade to 24mm front swaybar will only require the new bushings. The stock bracket should be fine.
Trick with this is to have a little patience. I have done this twice on the front end. Most bang for the buck is to support the frame of the car, and lower the rear of the subframe a little to get the bar out and to make better access to the swaybar brackets and bolts.
First you need to disconnect the front swaybar end links from the bar so it can rotate.
What I did was use a bottle jack x2 to lower the rear of the subframe. Once you have the subframe supported, loosen the 24mm nuts connecting the power steering rack to the subframe. This will allow the subframe to lower when you next loosen the rear subframe bolts.
You may need to loosen the front subframe bolts a little to give the play you need. Once this is done, and the rear of the subframe is lowered a little, the bar is a cinch.
Be sure to ****/grease the new bushings well, and torque them to spec. -- don't break the bolts on the swaybar bracket, or you are dead.
While you are there, replacing the end-links is a good idea. Also I would use TPR if you can afford it -- RCM has them
http://home.earthlink.net/~rcm_automotive/index.html
also check out these posts:
http://www.shoforum.com/showthread.php?t=70382
PM or post back if you have any trouble with this project. Like most suspension jobs, well worth the time.
JD
