thecrew2999
3.2 MTX SHO
ok the question is when i was driving my car last time (been sitting all winter and i did stuff to it threwout the winter) i noticed when i would turn the wheel side to side it would take the car a minute to catch up then it would like lunge into the turn.
i got 24/26 sway bars, tokico rear struts and all stock springs. also just added a stb up front, now ive been planning on doing suspention upgrades this summer so this isnt a real big concern.
not to mention i need an alignment bad because i dropped subframes and swapped them for my atx to mtx swap.
also got new strut mounts up front and the rear ones look fine but they are all oem mounts.
i know it needs an alignment because the wheel is semi turned to go straight and it slightly pulls to a side if i let go of the wheel.
if anyone is wondering i used the mtx springs because i know the atx springs are slightly stronger for the added weight. well im not certain just a guess and what i heard.
the last thing is the rear tokicos are off a 92 and my car is a 95 so they are longer and i got the sway bars and the HD end links off the 92 donor car but the thing is whenever i had taken the 95 rear struts off and put the 92 tokicos on the car i had to use a jack to push the swap bar brace bracket up to get the bolt in then i just used the bolt to pull it up. well when i did this looks like the rear HD end links push towards the back of the car angled like. where as it didnt do it when i had the 95 struts on.
any ideas guys? mine is that the 92 tokicos are much to long for the end links.
any solutions.? thanks:type:
or you won't have any tires left at all!
I'm sure the ****** tires are making a big difference. I sure notice a difference when I go from my winter mark snow's, to street rubba.
