Suspension
lunchbox0029
Fort Worth
I want to lower my SHO.
Is their a best spring rate and after I lower it
will I need a camber kit will there be a camber problem. I want to lower it 1.0 front .50 rear.
95 auto
DHMag
Free At Last
InCahoots, Texas
for a 1"/.5" drop, easiest way are Eibach springs. any lower than that and you will run into camber problems. i am running stiff Moog springs with 1 1/2 coil cut from the front and 1 coil cut from the rear. this resulted in a 2" drop all around. i then coupled the Moogs with Tokico struts not only for better handling, but to insure the strut can handle the spring rate.
Eliw
Brooklyn NY
I just finished installing my front Tokico / Intrax setup and it lowered the car more than expected. I didnt take official measurements, but now I have trouble putting my 2 1/2 ton jack under the car from the front. The car is also visually pretty low in front.
