Ok I received my BMR rear control arms. I'll be installing them this weekend.
For the guys that have used these do they need to be shortened at all??
I have the plugs for the Brake Brackets and the SHONut GTP kit. I'm also replacing the sway bar bushings/end links while I'm under there.
Any suggestions on alignment setting would be much appreciated. I was thinking for the front
Max caster, -1 camber and 0 toe. For the rear -.5 Camber and 0 toe. Thoughts???
