Struts + Springs
OSU 4 SHO
Westerville, OH
I was thinking about an alternative to the koni/tokico/eibach combo. What about getting Motorcraft struts and Eibach springs? Would the Springs alone lower the car a little yet with the Motorcraft struts, keep it more of a stock ride? I would also get 24mm, 26mm sway bars and bushings. What do you think?
Ishodu
With a lowering spring and stock struts you will have one bouncy ride very quickly. The higher rate of the springs will be too much for the stock struts.
Try a search this has benn talked about many times.
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Like Marcel said, the stock struts cannot handle the higher spring rate of Aftermarket lowering springs. They will lose damping performance very quickly and have the pogo-effect over even small bumps.
Bizzy
Ishodu:
billyshoe:
Eibachs are ***** soft and will work ok with any availible strut.
I guess you haven't been in a car with them then.
Ditto that. Billyshoe, in the future figure a different way to word your descriptions.
91 SHO PLUS
COLUMBUS, OHIO, USA
From a previous post: Aaron, you really need to find a way to come up with the $800, dude!!
Brand new Eibachs/Tokicos = $645 cost on Shoforum group buy!
Brand new frt.& rear mtg. plates, frt. bearing plates, and front & rear spring insulators = $220 from FPN!
24mm/26mm Gen I swaybars & brand new TPR bushings = about $140 cost!
$1,000 worth of new suspension, for only $800 is a steal of a deal!!
And, if you act fast, I'll throw in TWO K&N panel filters in excellent condition, plus a cool SHO windshield banner absolutely FREE!!
******************Aaron, here's an offer that I'll be shocked if you refuse:
All of the above: Eibachs, Tokicos, Factory mtg. hdwe., 24mm frt/26mm rear swaybars, TPR frt/rear swaybar bushings, TWO K&N panel filters in exc.cond., nice SHO windshield banner, PLUS upper & lower Motorcraft radiator hoses(just remembered I had these from previous owner) for a give-away price of just $750!!!!!!!!!!!!!!!!!!!
Let me know ASAP.
Jeff
614-235-7408
