Struts and springs.
MADDOG11
Houston, Tx. Denver, home
Just a quick question. Are spring compressors needed to remove old assem's
from the vehicle or just take the weight off the suspension? Thanks. :hpoop:
slickn56
North Attleboro, MA
Nope. The whole strut and spring assembly will come out without having been compressed. I use a long (6 ft) pry bar to pull the spindle down to get the strut out.
Shoaz
Studly dood
Scottsdale, AZ
You only need the spring compressor to disassemble or reassemble the spring/strut assembly. You can take the spring/strut assembly out of the car without the spring compressor, you just can't take them apart safely without it.
38SHO
#1 Oil Abuser
North Palm Beach
I love big prybars, they get the job done....and if it doesn't, get a bigger prybar
