steel vs plastic link?
quikSHOilver
Yamahaized
Indy
I want your opinons on whether would be better... steel or Plastic/nylon sway bar link for front. I am for steel however...
My understanding is that the ball joints on the ends of the steel links were pretty weak and tended to go out quickly, while the joints on the later plastic links were much more stout. I've read that the plastic ones are the way to go.
Storm-Chaser
Shit Louis
It's all relative . . . .
. . . . relative to whom the manufacturer is.
Moog makes a steel-based end link, which I think most will say is heavy duty. This same endlink (Moog K8702) is sold by AutoZone under it's Duralast name as part number SL239, for $25.99 ea., with a lifetime warranty. This is an all-steel heavy duty link with greaseable fittings, and is also carried by RCM Automotive.
Here are several reference threads, which are easily found using the Search function above:
:burnout:
quikSHOilver
Yamahaized
Indy
Thanks for your point on the search function, Yes I am fully aware of its function... I have searched thru and found none reffering to my question.
I asked for your opinion on whether is better steel or plastic, not on what brand link to buy.
I currently have moog greaseable zerk fitting K8702. Yet your recommendation from above was what I have now.:thankyou:
Phoenix
SHOHOLIC
QC , Canada
Both are good , but if you have harsh roads (like in MI) go with steel , they withdstand better some good potholes.
yamahaSHO
E85 whore
Arkansas
At the expense of your sway bar... I've seen a front sway bar bent on Pat's car. I think I'd rather replace and endlink than a front sway bar.
I personally have the Windstar aluminum links.
Kens1992mtxSHO
The Commonwealth
I had mine (rear) replaced with the Duralast (moog) brand 6 months ago. I'm getting another knocking sound from the rear when going over bumps. I will crawl under the car today and check it out. I'm hoping it's something simple like the end link snapped. I'll be taking advantage of the lifetime warranty if so...
38SHO
#1 Oil Abuser
North Palm Beach
more info on these aluminum windstar links please....
as in what years.... oem or an aftermarket brand.. or does it not matter?
hawkeye18
Sorta cares
Norfolk, VA
I'm starting to get the opinion that some people are just hitting the "search" button without actually typing anything into the search field. I have heard, over and over and over again, people say that there aren't any posts on the subject. Frankly, :bs:. There are something like 500,000 posts on this board and you're telling me that not one of them has covered this subject before?
I think the problem lies with the user, not with the forum. Yes, you have to search the right words, right forums, etc. but really it's not that hard. Try more than one term - I'm confident you'll come up with something eventually. Not everybody makes posts for the specific function of being found in searches later.
yamahaSHO
E85 whore
Arkansas
You're such a dick....
Shoaz
Studly dood
Scottsdale, AZ
I like the plastic units. They're definitely light, which is important to me. I've never personally had one break and I don't think I've ever had one fail any other way, either.
Plastic all the way... ;)
AREA 91
PA SHO SHOP
Area 91
I rock the Moogs with zerk fittings. They also have a "nut" on the backside of the stud that helps with install and removal.
tinkerkathleen
