sqeeking than smoke up to my ears..
aleksander j
sho *******
norway
hallo alle folk..
today i was about to drive my old grandfather down to the city.. the only thing was, my beauty wouldn`t come along.. 200 meters away from home a sqeeking noise came, just like the sound of a old volvo`s fanbelt..i took the foot of the gas to get a low idle and the sound dissapered(happened before and it worked fine).. when i continued driving the sound came back and i was now about to turn in to a bigger road and had to stop.. the idle dropped and the car dissapeared in sm0ke.. rigt now i`m sitting here with a terrible taste im my mouth.. tryed to look into the engineand nothing were on fire, but the smoke was heavy.. i let the car coole down for a minute or 2, and then try to start it agin.. starts fine and run fine for about 3-5 secounds, the the idle drops agin..
the powergenerator(dont know the right name), was a bit warm and i didn`t have any lights on the dash..
can it be the timing and accessory belt
please help me and don`t let this **** up my christmas
projectSHO89
SHOless In St L
Can you tell if the smoke was from an electrical source, oil, rubber, or coolant? Each has its own particular odor.
The noise sounds like a belt squeal. It sounds like something (like the alternator) may have seized and caused your accessory belt to slip and to smoke from the slipping.
Did the squealing take place while the engine RPMs were down?
Are all the lights on the dash out now?
Your best case is that the belt is just loose. I don't think yoou will be that lucky, though.
Christmas is in the heart. This is just a car.
Steve
aleksander j
sho *******
norway
had it checked.. it was the a/c compressor.. it was stuck.. they dissengaded it and no problem at all, exept when i turn on the a/c, the idle dropps to about 500 RPM and goes up after a few secounds.. are the bearings broken?.. can it be fixed or do i have to buy me a new one..
about the christmas.. last time i had the car in for bugfixing it costed me 2000$$.. no present for this christmas if i had to cash out the same ammount this time.. + i`m 19 years old and don`t have SO much money
thanx anyway,, thumbs_u
projectSHO89
SHOless In St L
Sounds like the AC compressor is seized. The smoke was probably your compressor clutch going ******.
As long as the bearings are ok, it will run that way. Make sure that they disconnected either the compressor clutch coil or the pressure cycling switch to disable the compressor clutch.
It sounds like the clutch is still trying to engage. Make sure it gets disconnected, then perform the idle relearn procedure.
If you need AC next summer, you can fix it then. You will have to adjust to defrosting without AC, though.
Steve
rangerj
Brunswick, Ohio
Aleksandej,
If your A/C compressor is siezed, the follow the directions given above. Diconnect the electrical connection to the A/C clutch coil or the high pressure switch (or low pressure switch). This will prevent the A/C compressor from engaging.
If however, your A/C compressor pulley bearing is siezed, it can be replaced (the bearing) as a separate replacement part on the 1989 through 1992 SHO A/C compressor. The bearing is pressed into the back of the pulley, and is held in by a spring.
If you find out that it is the bearing in the pulley, research the archives, or get back to us for the replacement process or part numbers.
rangerj
crystizel
