sockets needed to replace lower control arm
sho_u
port vue, pa
hi,
just wondering if anyone knows what size impact sockets i will need to remove my lower control arm on my 94
thanks
bryan
DHMag
Free At Last
InCahoots, Texas
sho_u:
hi,
thanks
bryan
18mm wrench + 18mm socket and rachet for LCA to subframe bolt.
24mm socket for LCA to torsion arm nut. vise grips to hold the torsion arm if needed.
masho95
got Zex?
Chicopee, MA
DHMag:
sho_u:
hi,
thanks
bryan
Also 18mm socket for the crown nut on the tie rod end. 18mm wrench for endlink nut and 8mm (deep is preferred) socket for the hex head of the endlink.
Edit: You don't need impact tools for the nuts I listed above.
<small>[ March 31, 2004, 08:53 AM: Message edited by: masho95 ]</small>
sho_u
port vue, pa
thanx guys,
has anyone used air rachets on this job??
unsure of clearance on lca to subframe bolt.
<small>[ March 31, 2004, 07:03 PM: Message edited by: sho_u ]</small>
masho95
got Zex?
Chicopee, MA
sho_u:
thanx guys,
You'll be the same off with out them if you have a 3ft or so pipe to put over your 1/2" ratchet. You'll probably need something like that to break them free. IIRC you should be able to get an impact on the bolt head of the LCA to subframe bolt/nut assembly.
