Smoke coming from under the throttle body
CTOESHO
DeKalb, IL, USA
At idle, there is slight sight of smoke coming from under the throttle body. It looks like a white, but evaporates really fast kind of smoke. Do you know what this is? Thanks
Mike
93MTX
Look to see which hose is leaking. There are several short hoses under the throttle body. To buy a couple feet (for spare hose) of 1/4" coolant hose at an auto parts store will set you back almost a dollar. If it is one of the heater hoses, it may be a bit more involved, but will still take less than a couple feet of hose and about a buck. Having a shop do this will cost you much, much more.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
jimbobzsho
westland mi usa
if it is the heater hose half of the hose is rubber and the other is steel what i did was cut the steel in half and got a pice of hose and clamped it to the steel and reinstalled it
dan.delargy
