Smog issues
rocket455
Fairfield, Ca
So i need to smog the SHO and visual passed *whew* but turned out to be a gross polluter when it came down to the emissions test.
15MPH %C02 measured:12.9
%O2 measured 2.71
HC(PPM) MAX 77 GP 283 measured 297
CO(%) MAX 0.50 GP 2.21 measured 0.01
NO(PPM) MAX 537 GP 1957 measured 0590
Results G POL
25MPH %C02 measured:13.2
%O2 measured 2.54
HC(PPM) MAX 58 GP 233 measured 233
CO(%) MAX 0.40 GP 2.08 measured 0.18
NO(PPM) MAX 494 GP 1757 measured 0429
Results FAIL
on a side note they offered to diagnose it. so they did and the cylinder balance test came back fine but the compression test was off
Cylinder balance test
CYL A 83%
CYL B 95%
CYL C 100%
CYL D 95%
CYL E 85%
CYL F 78%
PASS
VIRTUAL COMPRESSION TEST
CYL A 100%
CYL B 70%
CYL C 90%
CYL D 85%
CYL E 100%
CYL F 100%
FAIL
any input as to what would cause those emission results?
deercrusher
never running!
PA
you probably need a new exhaust valve in whichever cylinder correlates to cylinder B. That would cause your high HC readings and your lower compression in that cylinder. For good measure change your spark plugs too.
