rocket455
So i need to smog the SHO and visual passed *whew* but turned out to be a gross polluter when it came down to the emissions test.
15MPH %C02 measured:12.9
%O2 measured 2.71
HC(PPM) MAX 77 GP 283 measured 297
CO(%) MAX 0.50 GP 2.21 measured 0.01
NO(PPM) MAX 537 GP 1957 measured 0590
Results G POL
25MPH %C02 measured:13.2
%O2 measured 2.54
HC(PPM) MAX 58 GP 233 measured 233
CO(%) MAX 0.40 GP 2.08 measured 0.18
NO(PPM) MAX 494 GP 1757 measured 0429
Results FAIL
on a side note they offered to diagnose it. so they did and the cylinder balance test came back fine but the compression test was off
Cylinder balance test
CYL A 83%
CYL B 95%
CYL C 100%
CYL D 95%
CYL E 85%
CYL F 78%
PASS
VIRTUAL COMPRESSION TEST
CYL A 100%
CYL B 70%
CYL C 90%
CYL D 85%
CYL E 100%
CYL F 100%
FAIL
any input as to what would cause those emission results?
%O2 measured 2.71
Results G POL
%O2 measured 2.54
Results FAIL
CYL A 83%
CYL B 95%
CYL C 100%
CYL D 95%
CYL E 85%
CYL F 78%
PASS
CYL A 100%
CYL B 70%
CYL C 90%
CYL D 85%
CYL E 100%
CYL F 100%
FAIL
