SHO mechanic in New Jersey?
yaycandy
Aerospace Engineer
Hanover, PA
I knew of a real good one in New Jersey for Gen 1 and 2. But that was 20 years ago, my 90 has the repair records from them but every time I look them up I can't find them
Ny jersey or Philly Jersey? There are some area groups listed at the bottom of the forum and probably easier to spread the feelers out on Facebook if you're on it. (I'm not on FB but that's what it looks like to me)
jtaylor211
US
Im up in "ny" NJ.. BUT i wouldnt have a problem traveling. Im looking to have a 120 done.. and im left handed with 2 left hands
Sent from my SM-G965U using Tapatalk
These older car group members and resources are getting harder to track. Did you try the FB group? That might be an easier shout out over there.
jtaylor211
US
Yes i have, they told me id be better off fixing the car myself!
Ha ha. That's not surprising. I learned to turn a wrench owning these cars. What kind of work does it need?
jtaylor211
US
Its needs preventative maintenance, im thinking a 120k service, with timing belt and water pump..
Ok so there is a bunch of easy stuff for 120k like plugs and wires up top and look at the oil seals on the valve cover. I would suggest you do that yourself to save $.
The front of the engine-- tbelt/h2o pump --you can get anyone who is a good mechanic to replace water pump and timing belt. It's not so special that an experienced tech should have an issue with it. Just be careful with 3 piece plastic cover over the timing area. It comes off in a certain way and you can break the pieces if you yank on them too hard out of order.
jtaylor211
US
I appreciate the vote of confidence! My plugs, wires and valve covers are in good condition. No oil in plug wells. One or 2 of the grommet bolts are seeping oil a lil bit. My main area of concern is really the water pump, timing belt, and one or more of the pulleys is loud. Also ive had reinforced front motor mount and extreme rear mount installed and my motor is STILL MOVING
Brumfield780
