CWhalenSHO
Just finished the top 60K. Using the Valve Clearance Worksheet, I have 2 valves that are out of spec. Rear Bank Exhaust Primary is currently at .38mm when checked.
Using the worksheet, I need to get a hold of a 3200 Shim?!
.3800[gap as found]-3000 [nominal]+2400[old shim]=3200[required Shim]
I also need a 3250
.2700[gap as found]-2000 [nominal]+2550[old shim]=3250[required Shim]
Were these sizes even made? I think these would be extremely large for shim sizes.
Thanks for everyone's help!
I also need a 3250
