SFC instalation question
RJ-92
Crappy NYS
When instaling the FPS style SFC's, what points in the chassis do I use to jack the car up? I want to go with the pre-loaded chassis setup. Thanx in advance.
Ron Wazz
Red 92 mtx 106,000
ss y-pipe,
dynomax exahust w/open mufflers,
street/strip clutch,
lt. weight fly wheel,
ss tq limiters,
bored out MAF,
UDPs, ported intake
Konis and Eibachs
Jibberish18
Chicago Il.
Can I ask how the car feels after you install the SBC's? Stiffer. Smoother. Bouncy? Uglier?
1990 Sable 3.0
"My goal is to have the ultimate Sable in road handling performance"
[email protected]
Albany, OR - USA
I'll let you know when I get mine installed this week or next.
I, too, bought a set from Nook. I'll be calling in payment this Wednesday, so I'll have them by Friday, and probably installed within a week or so.
fredhurderjr
www.neshospecialists.com
I have shorties. The car was much stiffer, and with stock slicers & tires, it is smoother on most bumps. Ride harshness increases a little more than with 17" wheels alone, but like I said, stock is good. Take a few offramp corners at 10+mph higher than normal without the pit in your stomach & you'll be saying, "what ride harshness" with a big smile on your face.
FordLover
Houston, Tx
what's estimated install time for SFC's?
The local mustang performance shop guessed about 2 hours, and at 70bucks/hr, that's looking to be an expensive install.
He also laughed at me and asked me why I wanted them on my FWD, then I explained it wasn't for increasing 1/4 mile times, but for better handling.
-Martin
AOL IM: FastTaurusSHO and Kyle5324
My girl
92 Silver UDP's, coneless, Alum SFB, SHOnut motor mounts
93 Green MTX, High Rev's Jr, lightened flywheel, grizzly paw TOB, fishtank lights, SHOnut motor mounts, K&N panel, coneless, SHOshop linears, tokicos, alum SFB, 26MM RSB, wigwag headlights, 225/55ZR16 firehawk SZ50's, G-tech [email protected], 0-60 in 6.31
My Webpage
ThrillSHO
Wake Forest, NC, USA
From a guy who's done it, 2hrs is more realistic. By the time you grind the paint off the car, move the fuel lines, test fit, weld, clean the welds, paint the connectors, put the fuel lines back, you've used all of two hours.
Add to that: modify a exhaust hanger, relocate battery cable (my battery's in the trunk), and seal the ends of the connectors and I spent 4 Hrs & 2 beers.
View
ThrillSHO Racing
93 ATX SHO
UDPs, LPM, 80mm MAF, K&N w/CAI Snorkle, 8mm Taylor wires, Koni Struts, High Rate Linear Springs, Camber plates, Adjustable rear control arms, Touque box brace, Poly bushings, 24mm front SB, 26mm rear SB, Alum SFB, Full-length SFCs, Front & Rear STBs, SS Y-pipe, Borla Cat-back, TransGo Shift Kit, Relocated battery, Five point harness, Five 2" gauges below the CD player, 225/45s on 16x7s
Very Low Very Fast
Toolman
Boost it!
Grand Lake, Oklahoma, USA
True, but most of that work can be done by YOU, not by the $60-75/hr shop. The welding alone should not take even an hour. Martin, come up to Tulsa and get them installed at my preffered shop for only $35. Then we can try them out on that awesome route again (this time with my coilovers
1slickRED89
Guest
Toledo Ohio
from a person who has had both kinds and none installed, i would have to say the long ones work better than short ones do. all things the same i incresed my exit speed on 'laylin RD. raceway' by about 5 mph. not sientific but this is about what i remember.
stock (-eibach,-stb's) 45mph
shortie style ~55mph
Long style ~60mph
i ran 55mph in a nissan wagon, and it takes a beefed up SHO to beat that speed.
Corey
89SHO
FordLover
Houston, Tx
I wish I could take a week and do that. That road alone would be worth it!
-Martin
My girl
My Webpage
ChrisR
Las Vegas, NV
That doesn't sound good. Do you think a muffler shop would be the best place to have this done? I'm getting mine next week, but was hoping I wouldn't have to spend more on the labor, then on the parts.
AutoXSHO
Glenwood, MD USA
I wouldn't trust a muffler shop to this job. Also, most probably wouldn't do it.
Find a high performance shop, or a Mustang shop. They will know exactly what you want and do it properly.
John V
jedhead
westminster,ca
My '91 SHO feels like it was carved from a single block of steel. All the body squeeks and creaks are gone. I hook up better too.
Bob
rasmith76
Howell, MI
Bob
End Quote:
That's what I'm hoping for. I bought a set for my car and my dad's several months ago and then I've never had the chance to have them installed. I'm hoping to find a place while I'm off for Christmas.
Randy
94 Moonlight Blue MTX
Lots of goodies
