qiksho
SHO Addict
Serious snap in driveline - Found Problem...what is it called??
Hey guys I have a major problem with my 93atx. Anytime you get on the gas or brake fairly hard there is a loud snap. Now watching from outside the vehicle while someone else drives the car you can actually watch the tire move when it does it.
I thought it was the subframe bushings. Yesterday I put in the aluminum subframe bushings and this did not cure my problem...just made it louder
I can't see anything that looks bad. What can do to try and diagnose this further? HOw do I check the tranny mount? I tried putting the ebrake on and doing the engine mount test, but I can't really see anything. Motor mounts are good by the way.
IT seems too violent to be a c/v shaft...but I guess it is possible. ONly does it from a stop and usually when on the moderately hard. Turning doesn't make it better or worse.
Does the tranny uses a primary multi-link chain and straight cut gears to connect transmission main shafts? This would be considered the main drive chain for the tranny. Anyone have history that this could be the culprit?
Any help would be greatly appreciated.
Thanks,
Brandyn
Ok guys I found the problem tonight when I swapped sub-bushings from my 92-93. The bars that go from the lower control arm??? to the subframe on both sides. Well where they attach to the subframe I can move them around and there is not much bushing left.
What exactly is this bar and bushings called? What is best to put back in there? Can I get just bushings?
Thanks,
Brandyn
Thanks,
Brandyn
Thanks,
Brandyn
