rough idle, dies during KOER test
93SHO_2
Omaha Nebraska
93 ATX 93,000 miles Symptoms: 1.)Idles at 6-700 rpm when stopped in gear, wavers up and down 2.)Idles at 800 -1,000 RPM when in park, wavers up and down 3.)dies when running the KOER test 4.)shifts fine all gears 5.)gas milage about 11 mpg in town
Recent parts: EGR, EGR sensor, IAC valve, throttle position sensor
KOEO codes: 111 all is fine ???
KEOR codes after it dies (are these historical codes since the high/low revs did not complete ?):172, 136, 411, 538 (both oxy sensors replaced within the last 5,000)
(EGR hint, lots of Liquid Wrench, when the tube is cold)
Markus
Ottawa, Ontario, Canada
93SHO_2:
I'm not sure what you are trying to say here. If, as I am guessing, you somehow got liquid wrench into either the induction system or the exhaust manifold, the liquid wrench may have affecting the O2 sensors. Am I on the right track?
93SHO_2
Omaha Nebraska
ripper - fuel presure 39 lbs
marcus - I should have posted that comment in the other thread where the person was having trouble getting his EGR off, my EGR came off OK I just had some difficluty with the small side plate that didn't come with the new EGR
