93SHO_2
93 ATX 93,000 miles Symptoms: 1.)Idles at 6-700 rpm when stopped in gear, wavers up and down 2.)Idles at 800 -1,000 RPM when in park, wavers up and down 3.)dies when running the KOER test 4.)shifts fine all gears 5.)gas milage about 11 mpg in town
Recent parts: EGR, EGR sensor, IAC valve, throttle position sensor
KOEO codes: 111 all is fine ???
KEOR codes after it dies (are these historical codes since the high/low revs did not complete ?):172, 136, 411, 538 (both oxy sensors replaced within the last 5,000)
(EGR hint, lots of Liquid Wrench, when the tube is cold)
