replacing rear rotor trouble
blacklabel
Hartford, WI
Alright, the rear rotors on my '91 are old and need changing. I picked up some new rotors. I got the wheel off and the 2 bolts holding the caliper onto the caliper bracket. Do I need to take the actual caliper bracket off to change the rotor or is there some way around this? It looks like I need to. I've tried taking the bolts off that hold the caliper bracket onto the actual main hub and they will not budge. I've tried PB and it still isn't helping. Is there any way to get the rotors off without taking the caliper brackets off? I wish I bought a rust free car.
Thanks
kzoosho
Holset HX52
grand rapids/kalamazoo
Jack it up as high as you can, get you a breaker bar and a pipe and away you go. its gonna be a little hard but youll get it . wish you the best.
1993MTXSHO
Its a Taurus...
Jersey
yup, thats how I had to get mine off, and my car is rust free:thumb:
red89sho15
harrisburg,pa
i just put all new rear calipers rotors and pads on my 89 i had to heat up the right side caliper braket with a torch to break it loose...my best advice dont break any or youll be crying
