replacing rear bumper reinforcement with SLO assembly
avatar28
Nashville, TN
I picked up a SLO bumper assembly from the local junkyard today. I'm still in the process of trying to get mine off without resorting to cutting the shock absorber with a sawz-all. My SHO cover seems intact so I plan to reuse it. One question, though. How do I attach it? Do I need to fit it over and then drill holes in the SLO bumper for the push rivets? Oh and how do I get those rivets out without outright breaking them and where can I find replacements?
avatar28
Nashville, TN
Okay, absolutely cannot get the bolts that hold the shock absorber to the body to budge. the 10mm bolts that hold the bumper to the shock absorber are rusted something awful. I doubt they can be saved, I'm not even sure they can be removed without destroying them and/or the bumper. Suggestions besides start cutting?
avatar28
Nashville, TN
Well I got the damned thing off. Used vice grips the grab it even though it was chewed up and tediously removed the bolt. The other two were much easier and I was able to get them with a combination of a 1/4" ratchet and my gear wrenches. Got the cover swapped without TOO many major scratches.
Only problem now is getting it back on. I had the shock absorbers in first but I couldn't get the bolts on the bumper to line up. So I (loosely) attached the absorbers to the bumper before putting it on. Got the driver side okay but now I can't get the bolt for the shock absorber to line up right. Had to give up when a thunderstorm came along and had some scary close thunder. Also rain running down the bumper and into my face.
32sho
texas
Which SLO bumper did you use? I need one for my 93 3.2 SHO. Did you use one off of a LX or GL model ? Were did you find the hardware to attach the SHO cover? Thanks
