Replacement Pedals?
0V3RC10CK3D
Washington
Looking to find some sort of replacement pedals for the Gas Brake and Clutch, I don't know exactly how they come off or how I find ones that fit, My main issue is they seem kind of small for my feet and it rains a lot here so whenever my shoes are wet they slip right off the rubber pretty easily. Looking for a bigger more harsh surface.
Sammy~D
Wrench Whore
Anoka, Minnesota
the brake and clutch are rubber but i belive the gas is plastic. i have a set of aftermarket pedals on mine for the same reason and helps out alot
0V3RC10CK3D
Washington
Are they hard to put on? I haven't taken a good look at it, i know i've seen replacement pedals at like....schucks and such. Do those work?
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Yes they screw in. I had to get a different screw for the e-brake cover though.
I like mine though.
0V3RC10CK3D
Washington
Ordered a set, thanks guys
Coupon code: 1135060621 for 20% off if anyone else is interested, worked for me.
SHO_DOODmorrris
Owner & Fanatic
Alberta
god when my dad bought our SHO i guess the previous owner put on those "ractive" pedals. they are the sh*ts very sippary when wet, honestly im scared to buy andting thats a smooth metal finish, in the pictures i see on that site besides the grooves ones they look slippery to me. is it just the pictures or what?
ManySHOs
South Jersey
They have a ton of traction. I'm thinking of changing mine out for the insert series; I may not pass NJ inspection unless I have a rubber surface on my pedals. I believe that the insert series would qualify as a rubber grip (The STi's and new Vettes have this type of pedal from the factory).
Ian
SHO_DOODmorrris
Owner & Fanatic
Alberta
sounds good, they are 89 bucks a set you said kevin? for any series? i would like to know what you are using right now manyshos. let me know if you get the insert series and if it makes a difference. thanks
-mitch
RAYJAY
WHO ME ?
UNION DALE PA
I have them on my atx and there the best metal pedals ever nopt slippery at all
installed
