dstig1
Just finished doing the LCAs myself. I will also add my thanks, Scott, for a nice write-up. I've had this all apart before, so I wasn't expecting many issues, but I ran into a couple problem spots. First, Scott, your point #7 is not optional:
Optionally remove top or bottom sway bar link nut for clearance.
I got the pinch bolt, the LCA-subframe bolt loose, and eventually - with 10 min or so on the impact wrench - got the aft tension strut nut off. Unfortunately, I am not in Texas so rust is a big issue. Anyways, the LCA end at the subframe would not clear the lower sway bar link. I still have the original steel/iron ones, and the stud at the ends sticks way out and wouldn't let the LCA past. Once I removed the upper sway bar link (remember to do both sides or you won't be able to move the sway bar!), then it was easy to get the LCA out by pushing the sway bar out of the way. Last time I had this apart in a major way was a few years back when I did 96 brakes and Konis, so it was FULLY apart. That may explain why I wasn't expecting the interference with the sway bar link.
I had no trouble reassembling the drivers side, but the passenger side I had trouble getting the LCA-subframe end into the bracket. The bushing was slightly larger than the opening. Enough pounding and prying made it fit. Dunno why it wasn't fitting. I wish I had read the installation part of your write-up as I had big trouble getting the LCA-subframe bolt back in. Eventually forced it, but it was painful. Had I torqued the tension strut nut first, it might have helped a lot. Note that Helms doesn't give you that tip - they tell you to put the LCA-subframe bolt in first.
Ah well, it's all back together and working fine.
Has anybody ever figured out an easy way to get the ball joint out of the knuckle? My best shot at it is a 2-step: 1. take small pry bar and push the ball joint down by levering against the hub or whatever that part is right above the ball joint. Doesn't take much force, so I don't worry about it. This gets it flush with the top of the knuckle's ball joint opening. 2. Get the big-honkin' 3' pry bar and vainly attempt to free the ball joint the rest of the way. The best angle seems to be starting from the front of the wheel, slide the pry bar over the LCA right near the ball joint aiming almost straight back of the car. Then pry against the sheet metal lip at the bottom rear of the wheel well (underbody). Eventually it just decides to pop loose for no apparent reason. No matter how many time you try the same thing, all of a sudden it comes free on one try that was no different than the previous ones. Any tips? Maybe I just need a bigger pry bar.
-Dave
'92 5spd, 140k (Minne-sconsin miles...)
-Dave
