SHOpar
Hey All,
I've been trying to find some time to do another 60K on the SHO, and I finally decided to pull the intake off late last week to see what I was in for before ordering anything.
The car has been burning oil for the past several years to the tune of 1 quart every 1K - 1.5K miles; nothing too major, but still annoying. I suspected it was valve stem seals, and when I got the intake off, here's what I saw:
I checked all the intake valves, and every one of them looks dry, shiny, and brand new except for the valve at the very lower right of the first pic. It looks clean, but definitely has a few drops of oil on the top of it.
I haven't pulled the valve covers to take a look at the exhaust valves, but it looks like only one valve has an issue so far. Should I break down and replace the stem seals while I have it apart or do the 60K and switch to a high-mileage oil to see what happens? For the past 12 years and 100K I have been running Castrol 5W-30.
I really don't want to pull the heads, so if I tackle this job, I think it will be with them installed in the car. I've read a few write ups on the process, and it seems like it's really tedious, but certainly doable with the right tools.
Also, any suggestions on what to use to clean up the gunk in the intake runners? I would rather not tear the whole intake apart if I can avoid it.
I did notice two of my plug wells were filled to the top with oil, so that's probably the source of the hesitation issues I've had lately.
At least I detailed the engine bay right before tearing into it so I had a clean environment to work in:
Thanks in advance for any input!
