replace roof- how hard?
HoustinoJillian
name's JUSTIN
usa
m aprts car has a sunroof, and mine doesnt, how hard would it be to move the parts car roof onto mine?
DubbaDooz
NE Ohio
Due to the fact that the Taurus is a unibody car, I think it would be a whole lot easier (and safer!) to just get an aftermarket power sunroof put in your car. i believe there would be some serious structural integrity issues in cutting the roof off of your car and welding another back on, much like you can't just chop the roof off of your SHO and call it a convertable.
I agree. The electronics and the drain tubes that run under the front and rear pillars would be a PITA to do. I would go aftermarket.
HoustinoJillian
name's JUSTIN
usa
the roof doesn't bolt on like some other body panels do? hm well, looks like no sunroof then.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
89SHOyeeahh:
The sun roof has its own seperate sub assembly that is welded to the roof skin. I don't think it's worth it, but you could just cut a hole in the roof for the window and weld the window frame assembly in. Fit and finish would be an issue, but the drain tubes are easy to install, same with a wiring harness. If the headliner is removed all that stuff is exposed. By the way, the window frame assembly covers the entire roof, from windshield to rear window. I've an entire roof with sunroof out in the garage from a 93 parts car, you can have it rrrreal cheap! The rest of the car had an unfortunate encounter with "SAWZILLA"
Perry Toledo,Ohio
HoustinoJillian
name's JUSTIN
usa
hm well looks like a whole lotta stuff that i shouldn't mess with.. actually, having some trouble getting my parts car.. i think i'll have to worry about getting my car back on the road before i even think about a sunroof :D thanks for all the help though guys
Don likes SHO
Richland, Washington
There was a yellow Taurus SLO around Spokane WA which had the roof cut off to be "convertible"
I bet it was crap in the corners, but the guy drove it like he had struck gold :)
Levand16
San Antonio, TX
I had thought about replaceing my roof with one that has a sunroof. It can be done but I don't think it's wroth the time. Replaceing a roof is pretty easy compared to do things like the rear quater panels.
