URLACHER54
has anyone done this, i was talking to a guy today and he said this is agood idea. anyone, pros and cons of doing this.
BlackonBlack89 said:but after 4k there will be a gain obvisouly. (not streetable)
SASHO91 said:please enlighten us.....
SASHO91 said:unless the motor is tuned, that tiny gain wont even be felt.
never really below 4kSASHO91 said:Do not do it... end of story. No questions asked... if you do have a question search, its been beat countless times...![]()
SASHO91 said:any dyno proof????![]()
guess i need to double check whom i get my info from......
jedhead said:Easy way for you to find out. Disconnect the vacumn lines to the butterfly actuators so they stay open all the time. I am sure your friend has far more automotive knowledge than the engineers at Yamaha who designed the engine and messed up with the intake design.
Bob
91_SHOster said:this is preety much what jedhead's saying, if you do this it's preety much showing you what it will be like removing it all together
NJSHO said:If you lost low end power with just opening the butterflies, what makes you think removing them and increasing the opening is going to do anything but make you loose more low end power? This is a tuned intake designed to optimize torque in the low rev range and high rev range.
SASHO91 said:that is incorrect....
when you simply unplug the secondaries, yes, they are open all the time. However, they are still IN the intake track.
I have a spare set laying around that i'll port, and seal up... see what it does..![]()
NJSHO said:If you lost low end power with just opening the butterflies, what makes you think removing them and increasing the opening is going to do anything but make you loose more low end power? This is a tuned intake designed to optimize torque in the low rev range and high rev range. By removing the butterfly plates you negate that effect.
