Remove lead 'part' in rear strut mount?
I removed my rear drivers side strut assembly today to begin installation of Tokico/Eibachs. I have read MANY posts in these forums about how to remove the top strut nut while holding the strut rod. Many posts say to use a crow's foot wrench and there is another method of using a deep 13/16" socket in combination with a 10mm - 3/8" drive socket used to hold the strut rod. I used the deep socket and 10mm socket and it worked beautifully to remove the original strut.
However, now I need to put the Tokico back in and have discovered a problem. The strut rod nut that comes with the Tokico struts is not 13/16" as original, also the top of the strut rod only has flats instead of the hex head of the originals. The 10mm socket will not fit onto the Tokico strut rod end and I cannot find a deep socket for 22mm that has flats (like a spark plug socket).
As I read more and more on this forum I noticed that many people say the crow's foot works but there is ABSOLUTELY no way it will come close
to fitting in the cavity where the nut goes. Then it occurred to me that maybe people either do not have, or have removed, the original lead part that fits between the strut mount and the strut rod nut. If I were to remove this a crows foot would fit no problem. I cannot figure any purpose that this part serves or any harm that would be done by removing it but there must be a reason it was installed. Can someone help me? What is this round lead piece for and is it safe to remove it.
Pictures
Pictures
Why not get a crows foot that fits before removing parts that you think are just getting in the way?
