Rebuild brake proportioning valve?
RStalveyARFF
too many shos
Georgetown, MA
you can get new valves I believe. They screw into the proportioning valve block. Either that or go junkyard shopping. Any taurus has the valves.
jcostantino
Coral Springs, FL
I'll see if I can find a used valve around town here... I guess that I'd just need to clean it up real good and replace the o-rings..
Jeff
Bizzy
jcostantino:
Jeff
Firstly, I wouldn't buy a used one. They're only about $80 from Ford Parts Network new. You'll play **** in getting one that isn't rusted all to crap unless it's from a southern kept car.
Secondly, there was a federal law passed that stipulates that it's illegal for a bone yard to sell them used. It's a safety issue.
If you really insist on getting a used one, I've got one you can have for parts or whatever. Just email me your addy. The outer connecting rod and bracket are pretty much toast, but the valve itself is good.
pete c
ellington, ct
I took my proportioning valve apart today. One side seems to work fine. With the valve screwed all the way in you can depress the plunger maybe a sixteenth of an inch. When this is done the flow, using compressed air, is greatly increased. The other side does not move more than a few thousandths when screwed all the way in and flow increase is negligible. The problem is with the valve, not the body, sonce it works the same, either side.
I inspected each valve and found that with the good one, the aluminum piece at the end slides with respect to the sleel sleeve with the 2 holes. This movement appears to be what allows fluid flow. With the bad one, there is no similar movement.
I worked it around with carb cleaner and brake cleaner, but there appears to be no improvement.
I stopped by the local ford dealer and he says the prop. valve is no longer available.
I will take a look at ford parts network.
Any of you guys out there that have installed plugs wanna part with your valves? If so, PM me please.
Thanks,
Pete
Don89SHO
Tenafly, NJ
I replaced mine on Monday along with the brake line. My brothers discount from the Lincoln Dealership he works at made it $60. I replaced the rotor (down to rivets)and caliper the week before cause the drivers rear brake was not releasing cuss . His attempt to "fix" the proportioning valve (wacking the pistons w/a mallet to unfreeze them) didn't work. My advise, Bizzys absolutely right, just replace it; Cheap, Available and the same amount of work. Besides, its your brakes, if one thing needs to work right on your car, its them. :)
<small>[ May 09, 2003, 10:42 AM: Message edited by: Don89SHO ]</small>
It can be eliminated by flaring the ends of the brake lines and inserting a coupler. Do not do this if there is no ABS.
NorthernSHO
Ontario, Canada
SHOZ123:
My thoughts exactly. I had mine removed about two months ago as mine was good and frozen and had my friend Thomas cut it out and insert a coupler. No more proportioning valve and no more worries. The car stops just as well if not better than it ever has. thumb
djsSHO
Ford Nut
Buffalo, NY, USA
Does anyone have the part # so when I go to the dealer I don't have to deal with a blank stare if the counterhelp is less than informed?
TIA! :)
