DemonNeno
SHOCAGO Freak
Alright, this is ******* me off! My '89 (eibachs & tokikos) has this rubbing issue. Now, i intially thought the 17s were causing it, which were 235/45's.. So i installed 215/60's on the slicers and ****! Still rubbing, but no where near as bad. Here's the catch, though! The car has -1 camber on the right rear & -.05" toe.. It has camber bushings, but they are made out of a polyurthene type material, so I'm not fully aware of what brand they are. My passenger side has .03 POSITIVE camber (which I can't get into spec with those ******** bushings... it'll through it out more positive, not negative! Possibly on backwards? Can't see how, but...) and -0.05" toe (but doesn't rub!), equivalenting to -0.7 cross camber & -.10" total toe. Rolled rear fender lips.. AND IT STILL RUBS?! My SAI look normal and the wheel wells dont look like they've been patched up, so I can't imagine the car was hit, at least not hard enough to tweak the cheeks out back!
Any input or ideas? Perhaps some specs that are preferable without compromising treadwear? BTW, i performed the alignment myself, tinkered with a couple of different adjustments hoping to cure the problem with no luck..
But you already know that.
