Rear strut caps/ mounts.
Mike Kopstain
Arlington Heights, IL
I know this is probably an obvious question, but how can I tell if the strut mounts on the rear spindles are bad? Will they physically be broken? I have a set of Tokikos that I pulled from my parts car and I assume that the mounts were replaced. Also, is there any way to reinforce these?
Not quite sure what you are asking. The struts are attached to the knuckles with a pinch bolt and there is really nothing to change unless you have a rusted pinch bolt. The upper strut mounts are parts that ahve rubber that can wear out and it might be a good idea to replace them with the new struts.
