rear spring/strut parts locations?
pete c
ellington, ct
Like a *******, I disassembled both rear struts at the same time, putting everything in a box without drawing a diagram how it all goes together.
Bought new, well almost new kyb struts and new mounts, one was really shot. Also bought new springs (moog CCs) after hours of sanding convinced me that the surface rust was a little deeper than first thought. Now it's time to put all this crap back together. The rubber spring isolators go at the bottom of the spring, according to the parts drawing from the dealer parts computer. It also lists some sort of part that goes between the top of the spring and the mount, but, it says this is only for 90-91. If I put everything together with nothing between the spring/mount, the spring has room to move around. I tried placing the lower isolator there and it seems to fit pretty well.
Could somebody 'splain wtf goes where. Pictures would be a bonus. I also have the rubber bumper/donut thing that Keeps the strut from crashing into the mount when bottomed. Also have the heavy metal spacer washer thingy that goes between the strut mount and strut rod bolt. On one side this piece, which I believe to be some sort of a vibration dampener, split in two. I was thinking about jb welding it back together.
I was thinking about putting the isolator on the top with nothing but a few coats of rubberized paint at the bottom. Problem is, one of the isolators is too big. Looks like it came off something else. My guess is some dolt threw this thing on awhile back. This could explain why the strut mount on that side was shot to ****.
Thanks,
Pete
