rear brake upgrade
bad_4dr_sho
Now what broke
Dickson, TN
Hello, Im going to install 89 SHO rear calipers on my 95 sho, so I can do the 11.6 inch rear brake upgrade. I already have steel braided hoses on the car. Is the rear brake hose going to work with the 89 calipers. thanks
jpSHO
Massachusetts
What's the benefit of 89 over 95? I have a 95 ATX and I thought any rear brake upgrade was for looks only.
MONSOUN MOTORS
Philadelphia
Well the 93-95 SHO's had solid rotors and the 89-92 had vented ones. It does look better but if properly installed with bias plugs you can prevent the tremendous nose dive you get from having bigger brakes up front ie 12.5" + kits. And to the OP you should not have any problems with the lines.
AREA 91
PA SHO SHOP
Area 91
89 SHO did not have abs.
You will want to get spindles from a 90-92 sho with abs.
These have the "vented" rotors, unlike your solids you have now.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
but he is going to put 11.6 on the rear, the adapter plate will determine which backing plate/spindle to use
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Also i wouldn't use an 89 as they have a unique bracket setup I believe, same calipers though.
