jelloslug
Digital
Is is possible to just flip over the valve shims and reuse them, or are they only hardened on one side?
Yet another reason to join me and the ranks of new shim snobs everywhere!Yamaha V6:
But if you scratch the surface removing the carbon / oil burn circle on the back side, you're still dealing with a rough surface.
Seems to me that, in essence, Ford/Yamaha is telling us that the shims in our SHO's should last 60,000 miles before the hard surfacing may be worn to the point where camshaft damage could occur. There seems to be a built in safety factor that, I am sure is agumented by regular oil changes. For the expense of the shims, is it really worth it to screw around with an expensive engine?shojuan:
But if you scratch the surface removing the carbon / oil burn circle on the back side, you're still dealing with a rough surface.![]()
Can't beat that warm fuzzy feeling!
Rick
I'm not worried. My Dad could make the shims that I need for cheaper than $8/each.Yamaha V6:
My preferred method is to replace the shims (while they're still available). Of course, I have been hoarding all of the used shims for when they're NOT available - folks won't want to spend $8 a shim later on, though supposedly SHO Shop has a new shim vendor.
Which is why when I do a valve adj I charge 4.00 a shim to offset the cost and everyone gets new ones. I still get all the common ones from Ford they cost me 2.80 a peicesdpatt:
After investing in a total of 240 shims at an average cost of $3.50 per shim, that warm and fuzzy feeling gets to be a little expensive - $840. There are two sides to every shim.
In store, online, or what?on another note, Autozone now can order OTC tools!!
Since you now buy the real thing for much less that $8, that hardly seems like a viable alternative. Even if Ford and all of the SHO vendors quit sticking them, you can always get them from a Yamaha shop for around $4-$5 each.Yamaha V6:
"I'm not worried. My Dad could make the shims that I need for cheaper than $8/each."
Yes, but will he make them with the same material, with the same rockwell hardness, and at the 1/4mm increments (+/- what tolerances?).
