Radiator Fan ????
Mrhappytuzi
Divorced from SHOs
Delafield, Wisconsin
So when my engine gets HOT my radiator fan does NOT come on.
So i thought it was that CCRM module or W>E> but for giggles i did a key on engine off test and the fan kicked in for about 10 seconds... What does that mean?
Did i break it? :snicker:
MADDOG11
Houston, Tx. Denver, home
Check to see if you have power to the fan. If so apply direct power to the fan. If nothing happens your fan is siezed. If the fan comes on you either have a defective module or sensor.
The point is the gage sender is not accurate. It is not what turns on the fan. If you are really concerned you need to get a gage that actually reports the output in numbers.
SuperHO
Mental Patient
St. Joe, MI
...or just wire up an aftermarket electric fan to a switch that you control...
