ret
Wanted to get everyone elses opinion on the actual problem going on here. It appears either my radiator fan or ect sensor is shot... haven't checked codes yet to see if there is an ect sensor code being reported, but I have gotten no ce light, so I would imagine that there's not a code for it.
The engine heats up a whole lot, up to the N in normal when idling after I have been driving, as soon as I start moving and air starts flowing the engine cools down... on city roads(25-35mph), down to maybe the M, out on the interstate doing 60-70, the temp drops down so the needle is at the A or L as it used to always be. On occasion once the needle hits the N, the temp will drop down to the O or R then heat back up then drop down, etc as if the fan may be going on, just a little too late and not for long enough. Where do you guys think the problem is? ECT, fan, or possibly the thermostat? I'll post again after checking for error codes after work today.
