SHOtimer
#2910
The flexplate on my 3.2 I am not using as it is damaged. So, I will be using the flexplate on my current 3.2. In removing these is their any special precautionary way to do it as not to damage anything? The Helms simply said to tighten it down in the star pattern and gave a two step torque stages.
Also, the Helms mentioned lining the flexplate up in exactly the same holes with the TC as it was removed, is this completely necessary?
Lastly, how can I hold the motor still while I break these bolts loose? It is on a stand BTW.
Thanx, Doug
Thanx, Doug
