SHOtimer
#2910
Ok I am going to be removing my heads and getting new HG's. I have several questions that I will list.
1. I am considering getting the valve seals and guides replaced. Is this something that a competent machine shop is capable to do to our heads? How much does that usually run?
2. If I am pulling the head just to redo the gasket and it wasn't overheated does the head need to be resurfaced?
3. When removing the cams the Helms talks about removing them with the chain and tensioner still attached. Is it ok to remove them one at a time with the chain and tensioner already disconnected?
4. When reinstalling the cams the Helms states: "The number 5 cylinder head camshaft journal caps function as thrust bearings for the camshaft. Always tighten number 5 cylinder head camshaft journal caps first."
-can somebody explain that a bit more in 'laymans' terms? I am not sure exactly what is being said there....since each cylinder has two cams.
Thanx, Doug
Thanx, Doug
