Mr95Gl
Mr Tire Iron
In anticipation of receiving my parts, I decided to go out and inspect a couple of things that were wrong with the car (squeaking brakes, no interior light, remove outer airbox, etc). Well, I get through all of those and I remove the intake hose, and MAF. I put a towel over the TB to keep any debris from flying into the intake. I went into the car, and turn the key in the ON position so I can turn the wheel, and left it in the ON position (did not start the car).
About 10 mins later, I heard a sound (as if the intake was trying to suck in air) followed by a puff of BLUE smoke. Very worried at this point, I took the key out, buttoned everything back up and started it. It started right up (with a waterpump chirp). I let it idle for 7-8 mins then it started to stumble, and idle low. . . . . .
At one point it almost cut off, then the RPM went up as if someone hit the gas pedal, went down to normal idle, and cut off. The same sound that occured while it was shutting off, was the same sound I heard when the puff of blue smoke came out the throttle body.
Should I be worried? I figure it cut off due to the bad CPS, and i'm only about 2 - 3 days away from receiving my 60K parts. What could the possible cause of this problem be? Thanks for any/all suggestions!
*EDIT* - running out to run the codes now!
