proportion valve?
roushi
Manitoba
Does anybody know where I can find a new break proportion valve for a 94 ATX?
93rev2sev
Hockeytown
Is this part specific to the SHO or does it work on all rear disk brake models?
roushi
Manitoba
I was told that this part has failed on me, its not letting break fluid to the passenger side breaks. Is it really needed? if not.. can it be bye passed?
SHObill
'The Collector'
Rochester MI-48307Detroit
Most definitely needed if you don't have ABS! It reduces flow to only the rear if you have no load=rear passengers,junk in da trunk!
johndallara
Chapel Hill, NC
brake proportioning valve
did the bypass/delete on both 95MTX and 95ATX, no problems with either car -- even tho ABS is questionable working on the ATX. cars both have upgraded front brakes, seem to brake better w/ less ploughing.
JD:salute:
