Power Steering
The_Detroit_SHO
Allen Park, MI
Power Steering feelsa a little rough... Makes somewhat of a grinding noise. I checked the power steering fluid and it seems fine. This just stated doing this about half an hour ago. Its never done this before. Could it be from the heat?? After one thing has gone bad on my car it seems like everyhintg slowly one by one is going bad. I almost wanna get rid of, and sell her now.
95 ATX
66k
Stock
Chrisssssssss
vancouver, BC, canada
Mine too. I would check the subframe bolts and make sure that they are tight. If you are not sure what to do for that, how's your alignment? If it is a bit off, then maybe bring it in and get it done, then the shop will tighten everything down for you.
Another thing to check is the tension on the power steering belt and make sure that it is not loose. Does the car belt squeal when you are at the farthest turning points? Maybe belt related.
